I want to upgrade the rear end
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
Hey all,
I am looking to upgrade the rear end in my transam. Currently its the stock 7.5" 10 bolt rear with a 2.73 one tire fire open diff. I was thinking of upgrading to a more heavy duty rear end that can actually take some form of power transfer without snaping axles every other launch. I figured that most of you out there have done a swap in this area so I figured I would ask you where you ordered the parts or the whole rear end ready to rock. If I can order a full rear end that is just a bolt in and go setup then that would be the best bet. Any websites would be greatly apreciated.
what is a 9 bolt. is this a rear end that was used is some GM cars. If so which cars. I will go to the wrecking yards tomorrow and get one.
I was searching on thunder racing and I found this items here. What do you think of this 12 bolt rear end. will this be a direct bolt in and a simple install?
http://www.thunderracing.com/catalog...&vid=6&pcid=66
hectre13
Dec 11, 2023 08:14 AM
ambainb
Apr 25, 2016 09:21 PM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
