Rear lower control arm replacement with a lift
Old May 31, 2022 | 09:05 PM
RAK's Avatar
RAK
I have a storage lift was wondering if I could just raise the car and replace the old Lower control arm with new ones, can I keep the load on the car while doing this or do I need to take the load off the suspension to replace them, sorry if it’s been answered before can only find videos of guys doing it with a Jack
Old May 31, 2022 | 09:14 PM
Chris 84TA's Avatar
Car: 1984 Trans Am Convertible
Engine: 355
Transmission: WCT5
Re: Lower A-arm replacement with a lift
definitely need the weight off the front end.
I have found it easier to do the job on jack stands myself.
Old May 31, 2022 | 09:49 PM
RAK's Avatar
RAK
Sorry I meant rear lower control arms not sure why I put a-arm
thanks for the reply
Old May 31, 2022 | 10:32 PM
Chris 84TA's Avatar
Engine: 355
Transmission: WCT5
Re: Rear lower control arm replacement with a lift
it is still easier with jack stands, you can put a floor jack under the rear end to adjust the position to take pressure off the bolts.
I bent one on my car a long time ago. I just jacked up the one side and put a jack stand under the car. then put the floor jack under the axle tube.
It is easier to get to the bolts with the wheel off.
Old Jun 1, 2022 | 01:10 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Yeah, just put a floor jack under the axle and pull the wheel and drop the control arm off. Nothing dramatic will happen as long as torque arm is still attached.
That side of the axle might move a bit rearward making it difficult to get the bolts aligned again. Either move it by hand (if you're strong enough), or put a drift rod thru the holes and use it to align things, or use a ratchet strap to pull the axle forward if needed. Sometimes it's really easy, sometimes not. Using floor jack to fiddle with axle height can find that sweet spot where things align.
Old Jun 1, 2022 | 05:29 PM
vorteciroc's Avatar
Top Answer: 1
This sounds like a painful accident waiting to happen...
Mr Froman
Nov 22, 2010 04:51 PM
ksrammstein
Feb 8, 2004 06:19 PM
Frains90RS
Aftermarket Product Review
Dec 12, 2003 01:05 PM
Frains90RS
Dec 10, 2003 01:49 PM
400Z28Racer
Southern California Area
Dec 21, 2002 03:16 PM
