Frame differences???
Old Aug 4, 2022 | 09:33 AM
Mspangler's Avatar
Car: 1991 Camaro RS
Engine: 5.7 Lt-01
Axle/Gears: 3:28
So I have a 1986 Camaro sport coupe with the 2.8, I want to put a carbutated 350 in it, I know I need stiffer coil springs, but my mom told me that my frame is different(especially the 1986 ones) and it won't support the weight/power. Is that true?
Old Aug 4, 2022 | 09:45 AM
Mspangler's Avatar
Car: 1991 Camaro RS
Engine: 5.7 Lt-01
Axle/Gears: 3:28
Re: Frame differences???
Also do I need a new k member and sub frame connectors?
Old Aug 4, 2022 | 12:46 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Your mom is wrong. 1982 frames do not have the holes for the proper transmission crossmember location for the 700R-4. '83 and later are all the same. K-member is the same on '82-'92...
Old Aug 4, 2022 | 01:21 PM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Is that true?
No. To have built 3rd gens with different unit bodies (actually, 3rd gens don't have a separate frame) dependent on the engine option would have been problematic, assembly-line-wise.
Much more info on this commonly-performed swap can be found here: V6 to V8 Swap - READ BEFORE POSTING NEW! - Third Generation F-Body Message Boards
Old Aug 5, 2022 | 12:26 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I don't think that's the real issue my friend. I think your Mom is gently trying to discourage you from pumping money into that car, and she might fear that the car will be ruined. Nothing against you, she's looking out for you.
It might turn into a bad decision. It might turn into a lifetime hobby (full of bad decisions ). I don't know, depends on your personality and your means (money). Playing with cars can be fun & frustrating, but I guarantee it will be expensive.
Old Aug 5, 2022 | 09:33 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Wonder if it was her car first?
Old Aug 6, 2022 | 11:22 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I agree
zstalker
Feb 24, 2023 10:58 AM
Damian Preece
Jun 12, 2022 11:52 AM
lilpuertorico84
Apr 22, 2003 02:24 PM
