Anyone cut their sportlines?
Old Aug 10, 2022 | 01:04 PM
88BLKTransAmGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 3.77
I have 4.0138 sportlines on my 88 and want it lower. I am wondering what experiences people have had cutting their sportlines. I replaced my front isolators with rubber tubing but kept the stock isolators in the back. I feel like I need to go down another inch all around.
Old Aug 10, 2022 | 01:48 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Anyone cut their sportlines?
Remove the rear isolators and see if that does it for you. For me it was too low and the ride was brutal. You can also look into weight jacks so you can dial in the height the way you want.
Old Aug 10, 2022 | 02:40 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
I think it looks perfect the way it is...
Old Aug 10, 2022 | 08:00 PM
Engine: 5.7 L98
Axle/Gears: 3.77
For some reason my passenger side is half an inch taller than my driver side
ground to fender height is
Driver side front is 26 Driver side rear 27
Pass side front 26.5 Pass side rear 27.5
Old Aug 11, 2022 | 10:29 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I too have a height difference with my sportlines. I recently put the stock isolators back in and made sure they are rotated in the perch correctly. I should probably remeasure. I would make sure the springs are sitting in their perches correctly.
Old Aug 31, 2022 | 07:34 PM
Arctic White 91 RS's Avatar
Car: 91 RS/ 99 T/A/ 72 Vette/ 02 Z28
Engine: LSx/ Dart400
Transmission: M6/ M6/ TH400/ 4L60E
Axle/Gears: 4.10's / 3.08/ 2.73
Yes, we cut the front Eibach Sportlines for my 91 RS after the car was LS resto-mod'd. It looked like an airplane on take off the front sat so high. The shop cut ONE coil of the front springs. Stance was perfect 🥰
However, the car road harsher than ever and bottomed out. Scrapping was frequent. It was impossible to roll the car over an oil change pit without lifting up on the fenders.
Got a set of UMI weight jacks and raise car 1/2 an inch - perfect, no more issues to speak of.
I wouldn't more than half a coil if you cut.
Total disaster.
Old Sep 1, 2022 | 07:31 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Old Sep 1, 2022 | 08:20 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Looks good as is, it will settle a little bit.
Old Sep 7, 2022 | 09:58 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I trimmed about 1/3 of a coil off the front to get the stance right on mine. No noticeable change in ride.
topduarte
Exterior Parts for Sale
May 20, 2025 02:08 PM
poopmybrittches
Members Camaros
Jul 30, 2021 12:37 AM
Parasoth
Jul 3, 2008 10:02 AM
IROC444
South Central Region
Jul 2, 2007 01:33 AM
