Torque arm bushing or something else?
Old Dec 7, 2022 | 01:37 PM
Roorancher's Avatar
Car: 91 TA Vert WS6-94 TA Vert
Engine: 5.0/5.7 LT1
Axle/Gears: 2.73-3.42
Hi All!
Monday when driving my 91 TA Vert (126K miles,) (I have all the records, I've had the car almost a year,) going low speed thru the bank drive thru I heard this constant, "clang" that seemed to change with speed.... of course, I only hear it at low speed, because at 60 with the windows up it's inaudible. Definitely a metallic sound. Also heard it when pulling in and out of the inspection bay. No vibration or anything else obvious. If I didn't know better, I would think someone put a zip tie on the driveshaft.
Ideas or best guess? I saw one YT video about a torque arm bushing and that was the noise, exactly.
This weekend I'll jack it up and spin the wheels.
TIA
Old Dec 7, 2022 | 06:01 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Torque arm bushing or something else?
Likely a bad trans mount but the only way to be certain is to climb under and start investigating.
Old Dec 24, 2022 | 12:29 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Agreed... though a poly torque arm bushing may tighten it up...
The poly trans mount seem too hard... let me know if you find a quality rubber trans mount...
Napa use to sell some, but part number no longer works...
Raf
Old Dec 25, 2022 | 07:09 AM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
I am going to try this one from Energy Suspension. I have it and the car is going to the shop Wednesday. I will let you know how this works, it labeled as a "softer" Poly and the reviews I read seem to like it and say it isn't as harsh as the red Poly. I am replacing a rubber parts store special that only lasted 2 yrs, I have no idea what brand it was but apparently it was not very well made.
Speaking of torque arm bushing I also purchased the same Black Poly bushing for it and will be replaced along with the trans mount.
Old Dec 28, 2022 | 12:47 PM
luvofjah's Avatar
That's the hard one... some people ok with it, others not... didn't work for me...
tyevans5
Sep 28, 2011 10:33 PM
camaro86
Mar 10, 2011 12:13 PM
dave mc
Sep 5, 2009 04:28 PM
quickL98
Dec 20, 2006 09:10 PM
