View Poll Results: Best suspension for overhauling and exhaust scapes the ground.
Best suspension for 3rd gen camaro
100.00%
Exhaust scapes ground what suspension is recommended
0%
Multiple Choice Poll. Voters: 2. You may not vote on this poll
Exhaust scrapes ground when going in bumps and sudden downhills!
Old Jun 11, 2023 | 08:13 AM
jesuscamaro1984's Avatar
I’m pretty sure that my suspension is worn out since when I drive and hit sudden steep roads and then going up hill it scapes the exhaust especially if I’m going a little faster. What is the best suspension in the market. Can either be stock or exhaust to help stiffen it.
Old Jun 11, 2023 | 01:16 PM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Re: Exhaust scrapes ground when going in bumps and sudden downhills!
I say fix both. There's an outside chance that your entire suspension is worn out but most likely your exhaust is toast and ready to replaced
Old Jun 11, 2023 | 03:32 PM
Your "suspension" is probably fine, except maybe some wore-out bushings & ball joints & such. None of which would have any particular bearing on exhaust scraping.
Springs & shocks on the other hand, if you haven't changed em out lately, are a different matter. That's hardly "the" "suspension" though; they're the "soft" wear parts; kinda like saying you "engine is bad" when your spark plugs wear out.
Check for the existence of the exh hanger that belongs in the middle of the system, at the rear of the transmission. If that's not there or its rubber section is broke (which is how it fails) the whole thing will sag in the middle ruthlessly under stress.
camarozz383
May 21, 2009 08:48 PM
Americanmouse
Aug 24, 2007 04:12 PM
