MIN. EXHAUST CLEARENCE.
Old Aug 20, 2007 | 11:23 PM
Americanmouse's Avatar
Car: 1988 IROC-Z28
Engine: L98(383tpi) modified
Transmission: 700R4 rebuilt
Axle/Gears: 3:73 10bolt rebuilt
Quick question I just installed a aftermarket exhaust system for my IROC.
And I'm getting less than 2" of ground clearence. I think I get it up to 3" but no more.
What is the min. that you guys would allow?
Old Aug 20, 2007 | 11:37 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: MIN. EXHAUST CLEARENCE.
obviously something is wrong with the routing, even my true duals have 4-5" of ground clearance.
Also hop onto the chicago regional board and say hello and join one of our BBQs or cruises, etc
Old Aug 21, 2007 | 05:29 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You fail to mention what you're running, so knowing if there's a possible fix is difficult. If you only have 2" of clearance, expect to drag/destroy something fairly quickly.
JamesC
Old Aug 21, 2007 | 10:26 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Shorties give decent ground clearance.
LT's are a totally different animal though.
Which do you have?
I have 2.25" of ground clearance. I just stay away from speed bumps and so far i've been fine.
Where's that?
Old Aug 21, 2007 | 11:12 PM
Car: 1988 IROC-Z28
I have long tube hookers, and I bought the y-pipe setup from hawkthirdgen.
I think They may have sent me the wrong exhaust. I emailed there tech guy today with some pics. I also browsed their website and I found a y-pipe that looks like the one they sent me which there saying is for a LS1 camaro around 98' or so.
My IROC is a L98 TPI with a 700R4 (see my cars profile)
xpndbl3; once I get my camaro running well I would consider local cruises, thanks for the invite!
Old Aug 21, 2007 | 11:19 PM
xpndbl3's Avatar
Car: 1984 Z28
Originally Posted by Viprklr
Where's that?
chicago board is .....
https://www.thirdgen.org/forums/nw-i...south-chicago/
Old Aug 22, 2007 | 12:27 AM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
The general rule of thumb to be completely safe (over most road bumps, etc) is the Dr. Pepper can test. Why Dr. Pepper? I don't know but I hear about it all the time. Basically if you can fit a soda can under the exhaust pipe, you are in the clear.
Old Aug 22, 2007 | 04:21 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Thanks. Kept skipping over it when I saw Indiana.
Old Aug 24, 2007 | 04:12 PM
Car: 1988 IROC-Z28
Thanks for the information guys. I know I'm not going to get Dr. Pepper clearence but I can get more than I have. My driveshaft loop can be modifed to not hang so much. I can probley get another 1"-2". I was told I only need about 1" clearence with my loop. Right now I have about 2-3" of clearence.
Thanks again for your help everyone.
zapr
Jul 27, 2018 06:03 PM
PurelyPMD
May 5, 2016 04:57 PM
86White_T/A305
Mar 6, 2016 01:48 PM
david068513
Sep 18, 2015 10:36 AM
89 formula TPI
Sep 7, 2015 10:19 AM
