Rear spring isolators
Old Aug 10, 2023 | 12:07 PM
LeeH's Avatar
Car: 89 Firebird Formula
Engine: 389
Axle/Gears: Moser 4.11
Are they worth replacing? If so, with what? I am finally (after 10+ years) getting around to finishing reassembling my bird, and I am looking at these to see if I need to replace them: I ran them through the sandblaster, and they seem ok.
(See my ongoing build thread at https://www.thirdgen.org/forums/memb...ula-after.html)
Old Aug 10, 2023 | 01:27 PM
Roorancher's Avatar
Car: 91 TA Vert WS6-94 TA Vert
Engine: 5.0/5.7 LT1
Axle/Gears: 2.73-3.42
Re: Rear spring isolators
They look fine.
Old Aug 11, 2023 | 07:55 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Kinda depends on what your doing with the car? Are you keeping it factory ride height or lowering the car? If your lowering the car with lowering springs you may or may not get the desired effect after with the lowering spring and using the factory isolators as they will add height somewhere between 1/2" and 1" depending on their condition. If they don't give you the effect your going for you could ditch them and use heater hose as an isolator. If you do reuse them you might wanna put a coat paint on the bare steel to help prevent rust.
Old Aug 12, 2023 | 06:44 PM
MarineIROC's Avatar
Car: 1989 Camaro Z28
My Camaro is lowered on Global West springs. I replaced my stock rear isolators with Prothane# 61709BL to reduce the raked look. The isolators are for 99-04 Cobras and fit perfect.
gt4373
May 16, 2020 11:09 PM
gt4373
Mar 23, 2019 11:09 PM
gt4373
Mar 17, 2018 11:02 PM
gt4373
Mar 18, 2017 11:31 PM
gt4373
Mar 19, 2016 11:15 PM
