sway bars
Old Jan 22, 2002 | 03:37 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
sway bars
will putting bigger sway bars on my car do much. are they worth the money.
Old Jan 22, 2002 | 04:03 PM
Z-Man 85's Avatar
If you have a Z28 you should already have the "good" sway bars. I don't remember the size but I know that it's the bigger one chevy put on third gens. The one you have now should be good enough for the street. What are your intentions with your car? I recommend you just change the bushings and end links. You will notice a great improvment.
Old Jan 22, 2002 | 04:05 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Depends on how much larger you're going to go. Check out the junkyards for the "cheap" way to upgrade to a thicker bar. For instance, look under an 85-up 2.8/3.1 f-body- you'll find a 34mm front bar. Later model WS6 and 1LE cars (ex: IROCs) came with 36mm front bars. I think your '84 has a 32mm solid front bar. While you're at it, instead of re-using the old rubber bushings, buy new polyurethane ones for both the mounting bushings and the end-link kits. Just moving to new poly bushings on your current bars will make a noticable difference compared to your +18 year old rubber.
Old Jan 23, 2002 | 06:00 AM
Car: 84 camaro Z28
Engine: 434sbc
i was just wondering if i should buy them. the ones on my car are pretty big so i'll just stay with them.
Old Jan 23, 2002 | 02:30 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
If you want to stick with your current bars, do the poly bushing upgrade. You'll need to measure the thickness of your current bars to order the correct bushings. If you don't have dial calipers, tighten down an open-ended adjustable wrench on the center of each bar. Then, measure the gap of the wrench using millimeters. We can use a "universal" rear bushing kit, but we can't use a universal kit for the front bar- the f-bodies have an offset bracket. Energy Suspension has their catalog online, go to http://www.energysuspension.com . When checking prices at http://www.summitracing.com , put an "ENS-" in front of the part #, and put a single-digit color code at the end. Some colors are "R" for Red, "G" for Graphite (black), "Y" for yellow, "B" for blue, etc. An example is ENS-3-5159R (for red 30mm rear bar bushings). Sometimes Summit will be out of stock of one color, but have stock in another color.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
