Air ride/lift kit recommendations
Car: 1988 IROC Z coupe
Engine: 5.0 Liter
Transmission: 5 speed manual
Hello,
I would like to have an air ride/lift kit for my 88 IROC coupe so I can lower and raise my car as I like, but don't want to have modify the undercarriage/body in any way or at a minimum for the install. Is there such a kit out there? If so I would appreciate recommendations, or suggestions.
Thank you!
-John
Thank you!
-John
Engine: 5.0 Liter
Re: Air ride/lift kit recommendations
Yes, but the header was calling out suspension, and that was incorrect with no one responding with information so I wanted to clear up the wording.
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Hello,
Thank you!
-John
Thank you!
-John
You might want to do some searching on both this site as well as a general Google search to get some idea of what's involved. It's a big job; not something to attempt unless you're an experienced fabricator.
Engine: 5.0 Liter
Thanks Ironwill. I was hoping for a bespoke kit, but I guess that was real wishful thinking. I'll be having someone else do it if I pull the trigger.. Appreciate your input.
