Power Steering Return Hose Connector
Old Jan 4, 2024 | 10:56 AM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
This is from my 1984 Trans AM power steering box.
I need to purchase the connector or the sealing ring. I believe it is the "ring" that is causing the leak.
I have o-rings but they seem thinner than the "ring" that is on connector.
Worst case I can try an o-ring or apply a little sealant about the current "ring".
Suggestions?
Old Jan 4, 2024 | 11:07 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Power Steering Return Hose Connector
It’s just a o-ring on a saginaw flare. I wouldn’t use sealant
Old Jan 4, 2024 | 11:44 AM
Go buy one of those assortments that has about a pound of all the various sizes in it. No doubt there'll be one that fits. It'll cost the same as ONE that you'd look up as "Saginaw power steering O-ring", and you'll still have about .995 pounds left for other things.
Old Jan 4, 2024 | 01:54 PM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
I'm pretty sure Harbor Freight sells one of those assortment O-ring kits. One of them should work.
Jordan Ruddick
May 22, 2020 08:26 AM
nickyakker
Aug 8, 2012 07:17 PM
jhaag
Feb 12, 2005 03:51 PM
Tom91Bird
Aug 15, 2003 12:37 PM
lavamadness
Feb 24, 2002 06:44 PM
