Dumb sway bar question
Old Jan 23, 2002 | 12:27 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
did all third gens come factory with a rear sway bar? I do not have one, and it seems to have bad oversteer and body roll because of it. My friend's 89 has one, but his car has the 'soft ride suspension' package, so its pretty puny. If my car did not originally come with one, would it have the holes drilled for the mounting brackets? Can anyone reccomend a good pair of aftermarket sway bars?
Old Jan 23, 2002 | 12:51 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Some early base model cars did not come with a rear sway bar, so it's quite possible your car never had one. I don't know if you'd have the holes or not. Instead of aftermarket, just look for used swaybars in the junkyard and get new poly end links and bushings.
Old Jan 23, 2002 | 01:04 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
But it wasnt a base model. Came factory with the 4-speed auto over the 3 speed, power windows, power locks. Ihave no idea if it had one, im the 8th owner of this car.
Old Jan 23, 2002 | 03:25 AM
Jza's Avatar
Jza
If it's not a Formula or Trans Am, it's a base model. Options have little to do with it.
Anyway, if it didn't originally come equipped with rear sway bar, the brackets that the endlinks connect to probably won't be there, so at the yard, you'll likely have to cut those off and have them welded to your car.
Old Jan 23, 2002 | 05:52 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Those brackets are bolted in, not welded.
Old Jan 23, 2002 | 01:59 PM
82camaro's Avatar
Car: 82 camaro SC
If you get a used one, you will need the oem brackets that connect the end-links to the car. Way back when, I went with a Hellwig brand aftermarket bar that bolts to existing holes on the car--fairly easy install. It's a 1 inch solid bar. I also have the Hellwig front 1 5/16 solid bar. You need to have a matched set of sway bars for it to handle correctly.
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
deracer
Apr 11, 2016 12:04 AM
Warlocksirix
Sep 3, 2015 12:26 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
