Koni yellow fronts no dust cover or bump stop
Old May 20, 2024 | 12:34 PM
91RS5spd's Avatar
Car: 1990 Camaro RS (IROC-Z Clone)
Engine: LO3
Axle/Gears: 3.08
About to install Koni yellow part number 8741 1030SPORT. Just unboxed one and all that came inside the box was the shock, washer, nut and A plastic washer that fits around the shaft. Is a dust cover and shaft bump stop not necessary? Is that plastic shaft washer used for coil overs? I’m wondering if I can discard it.
Old May 20, 2024 | 12:58 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Re: Koni yellow fronts no dust cover or bump stop
It's not required, but I put a set of rubber strut covers from Rancho over the upper shaft just to help keep it clean and debris free.
Old May 20, 2024 | 02:30 PM
91RS5spd's Avatar
Engine: LO3
Axle/Gears: 3.08
thank you! I think I’d prefer having some on there myself but it’s good to know I can put them on. Is there a specific dust cover from rancho? I’ll do a search here in a min. How about that white spacer? Thanks again
Old May 20, 2024 | 02:42 PM
I'd have to look it up, but there was a thread from many, many moons ago that added the Racho cover that I think might have the p/n. I'd have to look for it. As far as the white piece, I don't recall if I had to use it or not.
Old May 20, 2024 | 02:44 PM
Found it (I think this is the one):
https://www.thirdgen.org/forums/susp...trut-boot.html
https://www.summitracing.com/parts/r...FQeKaQod9qIAkA
Old May 20, 2024 | 04:29 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I normally use the original factory plastic covers but I've never used them on koni
Old May 20, 2024 | 05:16 PM
I think that I switched to rubber covers because the original covers weren't compatible with the Spohn strut towers that I am using on my GTA.
Old May 21, 2024 | 04:08 PM
91RS5spd's Avatar
Engine: LO3
Axle/Gears: 3.08
thank you very much! You are awesome dude!
88Z350
Exterior Parts for Sale
Aug 18, 2016 10:43 AM
hairysox33
Feb 9, 2013 04:31 PM
FSTFBDY
Oct 9, 2011 05:17 PM
billkennyjr
Interior Parts Wanted
Apr 8, 2010 08:42 PM
