Easy? Brake Question
Old Jan 23, 2002 | 10:43 AM
Drylar's Avatar
Hrm I am having odd brake problems. I suffered brake failure, so tried first to bleed the system. It never bled right, as I could not 'pump up the pedal'. I did a little asking around and was told the seals in the master cylinder could be blown, so ok, replaced trhe master cylinder. I bled the system again, and to my surprise, could pump up the pedal! Now the strange problem.... When I start the car, when I intially hit the brakes, nothing. I take my foot off, and the pedal SLOWLY returns to up postion. I press again, and they give a bit of braking, I repeat again to be able to stop. In effect, I have to pump the brake to get pressure enough to stop. This is not good. The system was bled right, no hoses are leaking, no pipes are crimped, the light doesn't come on, adaquate vacuum to booster, and brakes themselves are fine.
'85 Camaro IROC [LB9] : 4 wheel disc brakes
brand new master cylinder
Only lost 1/2 gallon of brake fluid bleeding and re-bleeding the f'g brakes. EPA guys, it was caught and given to Pepboys to recycle.
Any help is most appreciated.
Old Jan 26, 2002 | 03:37 PM
ede's Avatar
ede
check for clarity in the lines, or for a collasped hose
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
kyleb24
Aug 15, 2015 08:24 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
