8.8 switch
Old Oct 8, 2024 | 10:19 AM
DougRussell's Avatar
8.8 switch
Hello. Has anyone here ran the 7.5 rear end and switch to 8.8 and record any results as far as et’s? Current setup runs 7.55 seconds in the 1/8 and have a 8.8 ready to go (same gear ratio as 7.5) and was wondering if any et loss due to the change. I know the rear ends are different weight. Any previous experience or knowledge would be appreciated.
Old Oct 11, 2024 | 10:29 AM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Re: 8.8 switch
May just have to make some suspension adjustments for the new 8.8 but should be close for both rears since they both use the same gear
Old Oct 15, 2024 | 10:58 AM
Beeman's Avatar
Re: 8.8 switch
Biggest difference being is you save the track from cleaning up the mess when the 7.5 grenades, then having your car towed off of the track. You won't break an 8.8.
Old Oct 15, 2024 | 01:33 PM
Re: 8.8 switch
The 8.8 is slightly heavier. Maybe 20 lbs or something; not a drastic difference. 8.8 has slightly higher rolling resistance butt again only a minor difference.
Beyond that, there are any number of details that can affect ET, which won't replicate from one car to the next. LCA angles which can DRASTICALLY affect traction aka launch, U-joint and drive shaft angles, brake drag (you didn't say what brakes you're using), and so on. No matter what happened to somebody else's car, better or worse, yours won't necessarily be the same. Besides, sounds like you're doing it regardless, so it hardly matters anyway. What happens will happen.
Gizmoz28
Jan 26, 2019 10:30 PM
rufaast
Nov 3, 2017 10:03 AM
Lab Rat
May 28, 2014 10:24 PM
maroman88
Aug 4, 2005 12:26 PM
