Front end vibration on interstate, need help
Car: 1986 iroc z
Engine: 305 tpi 5.0L v8 F Vin
Axle/Gears: Stock?
Hey all, I have a recent problem that's come up.
if I go 80 or above, my front end shakes real bad, it makes my dashboard vibrate violently and makes it hard to steer. I really don't want to have to rebuild the front end lol
Thanks for the replies in advance and let's hope I can get to the bottom of this
Re: Front end vibration on interstate, need help
Yup, that's one possibility.
Out of round (separated) tire or bent wheel are some others.
Swap the front & rear tires and see if it changes. If it does, it's a wheel/tire problem. If not it's something else. Check to see if the brakes on either side are getting unusually hot; this would probably be due to a failed rubber brake hose. If not, it's probably loose steering parts (tie rod ends, center link, idler arm), ball joints, or strut mounts.
vrooom305
Nov 26, 2002 08:06 AM
