Which subframe connectors
Old Jan 7, 2025 | 08:58 PM
Mspangler's Avatar
Car: 1991 Camaro RS
Engine: 5.7 Lt-01
Axle/Gears: 3:28
I'm trying to decide which subframe connectors to use, the BMR ones have 2 models, 1 for "outside exhaust" and another for "inside exhaust". I want to run long tube headers, down under the body and then 45⁰ exit in front of the back tires. So I don't know if that would be classified as "in" or "out" exhaust. Lemme know
Old Jan 7, 2025 | 09:18 PM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Re: Which subframe connectors
Outside. Those pieces of steel are used to snake around the exhaust and make more contact points. The "inside frame" aren't compatible with OE or OE style exhaust
Edit: I'm blind I guess! You plan on running long tubes. In that case either or will work for you
Old Jan 9, 2025 | 08:11 AM
RoadRace's Avatar
Car: 85 IROC
Engine: 5.7
Axle/Gears: 4.11 torsen, 4th gen rear
Hi. the Detroit Speed subframe connectors are good, not a concern with the long tubes in my car. i also did some research on the location and design of subframe connectors for other cars and i found the same design that DS uses is the preferred method for chassis rigidity in other forms of racing with unibody cars.
tubesncubes
Fabrication
Aug 2, 2018 11:54 PM
Firebird sweden
Mar 10, 2015 03:20 PM
wgripp
Dec 2, 2005 02:20 AM
Duke901
May 4, 2005 12:11 AM
poncho9789
Aftermarket Product Review
Aug 29, 2001 07:49 PM
