Can be changed easily? Has anyone done this?
Old Jan 27, 2002 | 04:04 PM
1984Firebird502's Avatar
I replaced the transmission mount. Can you change the tourque arm mount as well? If so, it is hard?
Old Jan 27, 2002 | 04:14 PM
grumpygreaseape's Avatar
Car: 85 iroc,96 z28,96 Ram 2500,69RR
Engine: 383 with AFR heads.
Transmission: richmond 5 speed
Axle/Gears: 1991 w/1LE.auburn pro series.2.73's
nah-i think its harder ensuring that you get the correct one for your car-there are 3 or 4 styles that gm used over the years just take a good look at the one in the car, or if its toast look at the shape of the torque arm and note which direction the rolled outside "lips" face towards-drivers side or to the pass.side. plus the torque arm is going to fight your replacement efforts by wanting to slam up thru the top of the trans tunnel-depending how the car is supported to work on, hold it downwards with a block or set a prybar or something thru it so it dont suprise you-later
budofbama31313
Aftermarket Product Review
Sep 16, 2015 12:29 PM
BAMiller
Sep 14, 2015 06:38 PM
z28guy134
Sep 1, 2015 11:50 PM
19irocz85
Aug 26, 2015 07:54 PM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
