what do i need to lower my car??
Old Jan 27, 2002 | 11:20 PM
breathment's Avatar
Ok, can i just get springs and change them out?
when would i need to use different spindles? and why?
what about LCA relocation brackets?
is there anything else that i NEED to lower my car correctly?
Old Jan 27, 2002 | 11:58 PM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
Springs should do it if you don't plan to go too low. I would use the spindles if you went anything lower than 2".The spindles will keep your front suspension geometry correct and keep you from having alignment troubles from incorrect geometry.
Old Jan 28, 2002 | 04:14 PM
breathment's Avatar
so stock spindles should be fine if im going for about 1.5 - 2"??
Old Jan 28, 2002 | 04:30 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
The Eibach pro kit is made to drop the car 1-1 1/2 inchs with the stock spindles. In my opion these are the best springs out there for our cars. I don't care for there sportline kit thought.
Old Jan 28, 2002 | 04:57 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I have the Eibach Pro Kit springs.Had to cut a little off to get the ride height where I wanted it.Mine's a little over 2" lower than stock.
This required caster/camber adjusters to keep alignment within reason (currently -1.5 deg camber,+5 deg caster).
Spindles won't adversely alter your suspension geometry.These usually come in 2" drop .
I think most third gen owners with lowered cars are using the Eibachs (either Sport-Line or Pro-Kit)
-Rich-
Old Jan 28, 2002 | 07:01 PM
breathment's Avatar
i heard that using new spindles AND springs allows u to have a smoother ride as well as lower.. does this hold any truth? also, as far as autocrossing would it be better to get diff. spindles or will the stock ones with lower springs be really good also??
Old Jan 29, 2002 | 09:45 AM
Car: 92 Camaro RS
I haven't autocrossed myself, but the autocrossers that I know all use springs or coil-over setups.
-Rich-
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
