alignment
Old Feb 3, 2002 | 07:06 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
alignment
i am gonna be putting new struts on my car soon and iwas wondering if i can align the front end my self or do i need special machines and stuff
Old Feb 3, 2002 | 07:28 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
i need special machines and stuff!
Old Feb 4, 2002 | 08:10 AM
Norm Peterson's Avatar
Car: '08 Mustang GT
Engine: 4.6L
Transmission: º º 0 . . . |-|-|
Axle/Gears: 8.8", 3.55
Re: alignment
If you have a flat place to do the work and have some understanding of what you are trying to measure and how to measure it, you can do it yourself. A carpenter's combination square with a bubble level in the handle, a 6" scale that reads to 1/32" or finer, and two strings and something to stretch them between is all you need. And patience (when in doubt, re-measure). A calculator helps too, but isn't absolutely necessary.
The fancy machines make it possible to do alignments as a business at a price that people will pay. Assuming that you have a really flat driveway, can shim the tire points flat, or know its slope, you can read this mostly as "more quickly than DIY in the driveway". Not necessarily more accurate - that depends a lot on your individual patience.
I did my own alignments for years this way but recently upgraded my alignment equipment to a homemade camber gauge that uses a dial indicator for about $25 plus the dial indicator.
Norm
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
evilstuie
Sep 24, 2015 02:31 AM
89 formula TPI
Sep 20, 2015 10:54 AM
