Couple Spohn torque arm questions....
Old Feb 13, 2002 | 03:45 PM
CamaroX84's Avatar
I am installing my adjustable torque arm. I have a few questions. Do the torque arms come from Spohn already set at zero degrees? Also, when I set my angle finder on the torque arm, it will read like 1/2 degree. When I turn it around 180 degrees, but in the exact same location, it reads like 3 degrees. WTF??? Also, could someone explain briefly the idea of having an adjustable torque arm. I forgot if you want the pinion to be higher on the front side of car or higher on the rear side. Thanks in advance.
Old Feb 19, 2002 | 10:16 PM
CamaroX84's Avatar
btt
Old Feb 20, 2002 | 01:38 AM
Jza's Avatar
Jza
You want the yoke pointing slightly downward, with a total pinion angle of about 4° (or whatever Spohn is recommending for use with his products).
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
angel2794
Sep 8, 2015 06:22 PM
rudolphschenker
Sep 4, 2015 02:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
