front brake question..please read...
Old Feb 13, 2002 | 08:22 PM
IROCZ28RSSCLTSS's Avatar
my front brakes started squealing so i figured the pads were gone, so i replaced them, but after i looked at the old ones, they werent even worn down to the part that makes them squeal, so then i put the new ones on, they still squeal, what is up? someone please help me out.thanx
Old Feb 13, 2002 | 11:21 PM
turningfast's Avatar
It could be a few things. How do the slder bolts, o rins in the caliper and spacers look. These are often neglected and really should be replaced with the pads. They are all in a hardware kit (except for the bolts, which often just need a good cleaning with a very fine sand paper). How do the lttle stamped metal pieces behind the pad look, wasted or OK. You should also apply this silicone ype of substance to the back of the pads, which is supplied with bendix pads, I forget what it's called though
Old Feb 14, 2002 | 04:48 PM
thanx, yeah i used the silicone substance with the pads
Old Feb 16, 2002 | 07:54 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
I suggest spraying anti squeal compound on the back of all four pads. Another contributing factor to this problem. Is exessive rotor runout. If you have the rotors turned (OH my *** spend more money) will also help to solve this problem.
Thanx,ANDYZ28
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
