how do you know when to change or repack front wheel bearings??
Old Feb 16, 2002 | 10:34 AM
squirrelybird's Avatar
How do you know when your front wheel bearings need to be replaced or repacked? i was cleaning my wheels and i noticed grease around the center hubs. is this bad? what does it mean? thanks guys!
Old Feb 17, 2002 | 01:39 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
I go by mileade. When I hit 75-80k its time for new seals and a repack. The grease gets old and crusty because of the parifin content. If you see scoring or wear you should replace them. I did mine last year and I think it was under 50.00 for everything with synthetic grese. ALWAYS replace the seals!
Good luck,
BILL
Old Feb 18, 2002 | 07:36 PM
bradkeith's Avatar
The way i've always checked my wheel bearings was to jack the car up and check for back and forth slop in the bearings. I put one hand behind the top of the tire and one hand behind the bottom of the tire and try to shake the wheel back and forth. You can also check your ball-joints like this.
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
B_Dubya
Aug 26, 2015 05:09 PM
kah992
Aug 19, 2015 02:55 PM
wruiz
Aug 11, 2015 02:59 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
