Brand of Springs?
Old Feb 18, 2002 | 05:15 PM
ta350400's Avatar
Brand of Springs?
I am trying to find the best springs for my 85 trans am. I want to lower it and get a good weight transfer to help it hook up. Any help?
Old Feb 19, 2002 | 06:24 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
eibach http://www.eibach.com/
Old Feb 20, 2002 | 06:32 AM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
... check with Ground Control for suggestions.
Old Feb 20, 2002 | 07:39 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
**** eibach O_o the prokit is the exact same stiffness of the STOCK IROC/Z28 springs O_O only its 1" lower...so I would buy other springs. Such as global west or ground control. Me personally am going to buy coil overs. Where you can choose the stiffness of your springs. I'll probably getl ike 800lbs springs. Bye bye body roll
Old Feb 20, 2002 | 11:32 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I like my Hotchkis springs. A bit stiffer then stock. And with all the pothole filled roads around here, I'm not sure i'd want to go much stiffer.
Old Feb 21, 2002 | 12:49 AM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
Some springratios to thirdgens:Iroc front spring:548lbs/in,Hotchkis F:600lbs/in R:100 to 140lbs/in,Eibach Pro kit F:714lbs/in R:108 to 177lbs/in,Moog front part#5662:706lbs/in,Moog front part#5664:767lbs/in
Old Feb 21, 2002 | 12:56 AM
5 litre eater's Avatar
Car: '84 Trans Am
Engine: 350ci Sportsman heads, B&M blower
Transmission: Turbo 350
I've got the moroso trick front springs and they're great!They'll take a little while to settle and you might even need to cut them a bit for desired right height.But if you're after weight transfer, these are the way to go.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
dbrochard
Sep 19, 2015 08:13 PM
crzycamaro86
Sep 12, 2015 05:51 PM
SG91camaro
Sep 5, 2015 10:27 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
