the "wonderbar" how good is it?...
Old Feb 20, 2002 | 07:33 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
just wondering cause I could probably get one for cheap. Will it change the handling all that much? is it noticible? or is it one of those..."I think it helped O_o"
Old Feb 20, 2002 | 09:44 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
Its one of those "I think it helped"
I didn't notice too much of a difference when I put mine on. A little, and I figure every little bit helps
Old Feb 20, 2002 | 10:08 PM
james_85Z28's Avatar
Car: 2003 Porsche C4S
Engine: 3.6L
Transmission: 6-speed Manual
If you install a wonderbar along with as shock tower brace you cars' handling characteristics would improve so much it would seem like another car.
Old Feb 21, 2002 | 01:08 AM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
Transmission: pro-built 700r4: 2400 stall
actually I just put one of Global West's brace on I think it really made a nice difference under hard cornering
I think it was an impressive improvement
however without any other suspension improvements this by it's self probably will not do much good
just my thoughts
hope that helps
Old Feb 21, 2002 | 08:02 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I've read that, like SFCs, the wonderbar/steering box brace is protective in nature. The wonderbar protects the steering box area, which is subject to cracking (Note the how the car reacts in a parking lot on a sharp turn), like SFCs protect coupes from cracking above and just behind the side windows.
JamesC
Old Feb 24, 2002 | 02:23 PM
WS6Formula350's Avatar
I notice a while ago that my formula has a crack on the roof right by the window in the back top part.....how bad is tthis???? it's not a big crack, more like a hair line deal.
Old Feb 24, 2002 | 05:57 PM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
... mine came that way, with a small tear at the trailing corner by the 'B' pillar, but I've had Steve weld in some of his SFC's and they haven't gotten any bigger.
The 'wonderbar' is to help add support to the steering box side of the car. It does work best, as mentioned, with other improvements to be noticable.
gta90
Sep 15, 2015 04:00 PM
dcbsracing007
Aug 18, 2015 07:24 AM
Street Lethal
Aug 13, 2015 08:28 PM
