non-matched sway bars
Old Mar 3, 2002 | 09:28 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
If I have a 36mm front and 23 rear bar how will the handling differ from a 36/24 combo? Is it worth finding a 24mm bar to match the front?
Old Mar 5, 2002 | 11:21 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You'll be fine. The 24mm rear bar would make the car a bit tighter, but it won't be like your setup will suck. Add the polyurethane bushings to the bar. Supposedly by putting poly mounting bushings on an anti-sway bar, you make the bar "act" like it's larger.
Old Mar 5, 2002 | 06:27 PM
82camaro's Avatar
Car: 82 camaro SC
The 1 mm won' t make much difference. The smaller rear bar will make it push in the corner(tight), a fatter bar will make it loose. The opposite is true on the front.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
