Proportioning Valve question.
Old Mar 6, 2002 | 09:40 AM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
I put a '96 3.42 posi disc rear in my GTA. My GTA unfortunately had the optional drums (deleted disc) on it. I haven't swapped prop. valves yet. It stops ok, but not as great as it should. Question is that I have a prop valve off a '88 GTA with 4wd sitting here. Should I just use it or get a wilwood or something. Money is an issue so I'd rather just use the valve that i have off that '88. The dealer said that the '91 4wd valve and the '88 4wd valve I have are not the same part numbers though. Will that matter? Thanks
Old Mar 6, 2002 | 09:59 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
The '88 valve will not work on a '91. You need GM part# 10164112
Old Mar 7, 2002 | 01:36 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
re
Thats the number they gave me. It costs $70.88 though. Why can't I use the '88 valve? Should I just go with the adj wilwood valve or what?? Thanks
Old Mar 7, 2002 | 05:28 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I know 89 changed one of the brake line nuts, and I am sure they did more after that.
Old Mar 7, 2002 | 06:08 PM
ANDYZ28's Avatar
Car: 1982 Z-28
The thread pitch is different on the pre '89 (late '89) proportioning valve fittings. It won't fit.
Old Mar 8, 2002 | 08:21 AM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
re
I see. Thanks for the info. Guess I have to buy one now
Old Mar 8, 2002 | 05:44 PM
Engine: ls1, LB9
or get one from the many parted cars here.
fbodyfreakls1
Oct 6, 2015 06:34 PM
corey8084
Sep 17, 2015 02:56 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
Ian Irvine
Sep 4, 2015 08:08 AM
