anyone with Moog problem solver Ball Joints?????????????
Old Mar 7, 2002 | 07:04 PM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
I know its sounds like an easy thing but how do the grease cover things go on? I know where they go but how far do they go on? Do they snap on? I CAN'T get them to pull all the way down. One side will always stay up. Are they supposed to fit tightly or kind of loose? thanks..
Old Mar 7, 2002 | 07:13 PM
CamaroZ_85's Avatar
they should fit tightly. it's a PITA to get them on, in fact i dont even remember how i got mine on....but just an idea, find a socket or piece of pipe thats just about the same diameter of the bottom lip of the seal and use that to smack it on....the idea is to have even force all the way around that ring so it will pop on to the ball joint.
Old Mar 7, 2002 | 07:23 PM
Transmission: 4L60e
Axle/Gears: 9 bolt
Thanks.
I bought energy suspension boots for it too since hey were only like $2. They dont really have a lip on them and they just slide on very easily and fit very loosly But are ALOT smaller ( dont know if size matters for grease capacity or not). I dont know if these are any good but may end up using them If i cant get the moog ones on.
Do they really need to be on that tight??? Or will the Energy Suspension loose fiitting ones be fine?
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
greenyone
Sep 2, 2015 03:39 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
masonta
Sep 1, 2015 06:40 PM
