grinding down steering shaft for header clearance...
Old Mar 12, 2002 | 11:15 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
how do you guys feel about this?
i REALLY don't want to dent the header, and i already tried to move the steering column last year without any success.
i am going to try again to move it (i tried real quickly and may have missed something). but if that doesnt work, i think the plan is to grind a LITTLE bit off the steering shaft.
i dont do any autocrossing or anything, so there isnt going to be a huge amount of torque on the shaft greater than it would be during normal driving.
also, the "power" part of the power steering is past the steering shaft, so most of the torque doesnt go through it anyways.
BUT...what do you guys think?
-brian
Old Mar 12, 2002 | 11:29 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You would be better off denting the header. Use an acetelyne torch and heat up the header tube where you want to dent it cherry red. Just don't burn a hole in the tube. Use a hammer and tap the tube to the shape you need.
I had to redent my headers when I bought some new heads. Hooker already had a dent in the header tube to clear the steering shaft but the new heads moved the exhaust ports a little higher. The tube was rubbing on the shaft. I heated up the tube and used a hammer and punch to make the dent bigger. It doesn't touch the shaft now.
Old Mar 13, 2002 | 04:05 PM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
i agree, don't grind the shaft.
Old Mar 13, 2002 | 07:50 PM
89BlueTA's Avatar
I loosened the the three bolts that hold the steering shaft in place on the inside of the car. Then I took a wonder bar and beat it with a hammer between the header and steering shaft. This gave me about an 1/8" clearance. This might not be a method for everyone but it worked for me.
nick
deracer
Apr 11, 2016 12:04 AM
evilstuie
Feb 28, 2016 03:33 PM
92projectcamaro
Jan 18, 2016 08:00 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
