I can't figure it out... (Question about my Struts)
Old Mar 18, 2002 | 12:25 PM
GoldenSwordZ28's Avatar
Ok, Here is a problem that I can NOT figure out. After installing my KYB GR2 Struts in the front of my car... there is a click/snap noise that sounds like my Strut is moving around. PLUS it makes it real annoying to drive the car. At first I was under the impression the bolts were loose where the strut bolts into the steering assembly, and after tightening those it feels better and doesn't make any sound, but a few miles later after braking a few dozen times *PoP* it sounds loose again. But last night I pulled the wheel off and tightened it up with Red Locktight, I tourqued her down REAL tight (Trust me, I tourqe everything to death, this one didn't break though, it went in and did what it was supposed to do... tighten) and today on my way here to work, it started poping again..... WHAT THE HELL? I've also thought that it could be the Strut Tower.... but that seems fine.
I'm at a loss guys, I've got no more Ideas....what else can it be??
Adam
Old Mar 19, 2002 | 12:49 PM
'Kick'
Really need some help guys... I did a search last night and so far nothing has helped me out enough to stop the clicking, I need some new Ideas.
Adam
Old Mar 20, 2002 | 02:15 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Could it be a faulty strut?
Old Mar 20, 2002 | 10:32 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Don't over-torque...
How is the upper strut nut doing? Did you have an alignment done yet? Other than that, I'd suspect a bad strut, too.
'84 Z28? Got a 5-speed? Does it pop it's worst around corners?
Old Mar 20, 2002 | 11:24 PM
turningfast's Avatar
Did you check the bearings in the top mount, they should move freely, not bind and not have play in them. They are often overlooked.
Old Mar 21, 2002 | 09:33 AM
mtccl's Avatar
Top bearing in the upper isolation mount/alignment adjustment plate was my first thought also. They are like $80.00 each to replace.
Old Mar 21, 2002 | 02:12 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Geez, $80?!? Man, I hope mine never fail. Is that for "installation" cost or just the cost of the bearing?
Frozer!!!
Jan 19, 2024 04:55 PM
TheExaminer
Aug 25, 2015 07:34 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
