LCA relocation brackets- for G-Body Malibu/Monte?
Old Mar 20, 2002 | 04:15 PM
Damon's Avatar
No it's not an FBody question but I'd like to get an answer anyway, if I could. This is a popular mod on FBodies and I now have a need to do something similar on my 78 Malibu. But I don't know anyone who makes LCA relocation brackets for a G-body.
Anyone know of a place that does?
Old Mar 20, 2002 | 04:47 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You might want to check if the F-body ones will work... it's a definite possibility.
Global West is about the only people I know of that might have something A- and G-car specific.
Old Mar 20, 2002 | 04:59 PM
Damon's Avatar
No dice. Tried them already.
I'll look into a modified set of F-Body brackets, but I'd like something built for the G-Body if at all possible.
Old Mar 20, 2002 | 05:40 PM
BigL350's Avatar
Hey, Damon. I think I've seen you on the MonteCarloSS.com message board. I read a tech article on that site a while back that gives a spring/suspension part interchange list between F-bodies, G-bodies, and S-10's. One of the interchangeable pieces was the rear lower control arms, which made me wonder the same thing about the relocation brackets by Spohn. I just put a 3.70 8.5" posi rear in my malibu and SSM bars and Moroso trick springs along with it, so the relocation brackets weren't on the top of my S*%t t do list. Have you contacted Steve Spohn yet?
Old Mar 20, 2002 | 11:15 PM
turningfast's Avatar
I love the g body, talk about cheap capable car that can do it all(and has a full frame). I've never seen them, but a couple of racing buddies say that adjustable upper arms and good or boxed lowers are all that are needed to make them hook up well. Just a little change in pinion angle makes a world of difference
Old Mar 22, 2002 | 06:41 AM
Damon's Avatar
That looks like what it's gonna be- adjustable uppers and beefed up lowers. I'd love to get the relocation brackets and beef up the suspension's anti-squat geometry but it doesn't appear anybody makes them.
Spohn's website does not list any LCA relocation brackets for a G-Body.
Old Mar 22, 2002 | 06:12 PM
82camaro's Avatar
Car: 82 camaro SC
Yep, all you need is the adjustable upper arms. The effect of LCA relocation brackets won't be the same on a G-body--the rear suspension is different. The F-body transfers all the power through 2 control arms, the G-body has 4.
Old Aug 15, 2002 | 04:35 PM
Gruvin84SS's Avatar
G-body control arm relocator brackets
BMR fabrications has them under the G-body section
Old Aug 15, 2002 | 05:00 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Like I said, Global West has all sorts of A & G body stuff. Definitely check there if you haven't already.
The effect on the 2 suspensions should be exactly the same. The 4-link creates the same issue with the lower control arms, in the same way, as these cars do. I've had Chevelles with wheel hop from hell, I wished I'd known at the time what to do about it. I have one that I'll be dealing with soon enough, a 69 SS396 convertible that belonged to my late little brother.
Old Aug 16, 2002 | 11:56 AM
ATOMonkey's Avatar
It's just a piece of 1/4" steel. Fabbing one up shouldn't be rocket science.
Old Aug 16, 2002 | 01:42 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That's true too... if you had a way of doing a halfway neat bending and drilling and welding job, you could make some up yourself.
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Jorlain
Oct 8, 2015 01:57 AM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
89newfun
Sep 16, 2015 09:28 AM
