Brake Upgrade
Old Mar 22, 2002 | 02:37 PM
Black Knight's Avatar
Brake Upgrade
I want to buy either a Baer or Brembo brake upgrade kit for my GTA.
Can anyone recomend a place to buy them from and which size you have used yourselvesor think is the best value?
Thanx
Old Mar 22, 2002 | 02:42 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
IIRC the Baer kit is a little cheaper than the Brembo. What size wheels do you have? The Baer Track Kit uses 13" rotors so you'll need 17" wheels. The Sport Kit uses 12" rotors (they take the 13" rotor and machine it down) and will work with 16" wheels.
The Sport kit is $100 more than the Track due to the machine work.
You should be able to buy direct from Baer unless you can find a distributor who might be able to get you a better price.
Old Mar 22, 2002 | 03:36 PM
Thanx BretD
I am going with 17in wheels. So I could use the larger diameter rotors. What about the pro, pro+ or extreme+? Is that overkill?
Also, do you know which vendors carry them for third gens?
Regards
Old Mar 22, 2002 | 03:44 PM
TAZ28's Avatar
Thunderracing.com has the bears.
Do you have the 1LE right now ?
Ray
Old Mar 22, 2002 | 03:49 PM
Thanx Ray
I will check there site out.
I do not have 1LE now. I figured if I have go through the trouble of upgrading I am going to go with the best ( or almost the best) I can get
Billy Decker
Sep 4, 2015 03:46 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
rudolphschenker
Sep 4, 2015 02:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
Night rider327
Sep 2, 2015 04:18 AM
