"FRONT" rims in rear. Any noticable problems?
Old Mar 24, 2002 | 10:00 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I'm was going to go mount drag radials on my old stock IROC rims but the "rear" ones are really beat up. They have dents/chips everywhere. The front ones are perfect though. Would it really matter if I mounted the "front" rims on the rear? They're both exactly the same besides the rear having a 16mm offset (for handling?) correct?
Old Mar 24, 2002 | 08:24 PM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
the offset is for the brake clearance. The fronts will work in the back, the backs won't work in the front.
You may have fenderwell rub, running the fronts in the rear, depending on tire size.
Old Mar 25, 2002 | 12:20 AM
SpeedCat86's Avatar
Car: '86 TransAm WS6
Transmission: Custom TH700R4
Exactly. If you use the offset 'rear' rims in the front, they will rub like crazy. Using the zero offset 'front' rims on the rear has no effect other than showing more rubber around the sides of the fenders. I have zero offset wheels on all four corners, and they work just fine.
Old Mar 25, 2002 | 07:52 AM
IROC57TPI's Avatar
Anyone got any pics of 4 zero offset rims on a 3rd gen? I'd like to compare them to the standard f/r setup.
I hear of GTA guys doing this all the time
Infested
May 22, 2018 11:56 PM
Reddeath210
Oct 6, 2015 08:20 AM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
