Recommended Tire Pressure
I just bought an 89 RS V-6, and somebody painted over my tire placard. Idiot. So, can anyone tell me the exact, GM recommended tire pressure for an 89 RS? The tire pressure on the placard, that is. One of my tires looks a little low. Thanks,
Matt
Matt
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
Re: Recommended Tire Pressure
Matt
Matt
Hey Matt, I also live in Clinton and drive a red 91RS. I'm glad to see you found TGO, welcome to your new home.
Is it a front tire or rear tire thats low? Generally speeking the fronts require more pressure that the rear because the front end is usualy heavier than the rear. I usualy run about 32 to 35 in the front and 28 to 30 in the rear. Depending on tire size your tire pressure will probably a little lower than mine.
Steve
Steve
backtothe80s
Sep 5, 2015 12:39 AM
