Just put the 'Flyer' .......
Old Apr 4, 2002 | 04:03 PM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
..... back on the ground and out the door.
The road test was a blast on the new suspension.
The brakes will stop the T/A on a dime and leave at least 3 cents change now.
Added a couple of new pix showing the new stance.
Next - manual rack -n- pinion setup.
Can't wait until the trip to Watkins Glen. 2 days at the most infamous road course. Full course - 3.48 miles.:hail:
Old Apr 4, 2002 | 04:31 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
What is the new suspension and brakes?
Old Apr 4, 2002 | 06:40 PM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
  • the fronts have a ride height adjuster on top of the Eibach's that are now rated at 850 lb/"
  • Guldstrand poly a-arm bushings and HD Moog ball joints
  • Guldstrand poly sway bar end-link kit
  • the rears also have ride height adjusters with 175 lb/" springs
  • Spohn's adjustable LCA's and PanHard Rod
  • and a complete 1LE brake package from Stainless Steel Brakes
There is a pix link in the sig
Old Apr 4, 2002 | 06:52 PM
racereno's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
I LIKE!! Now you're talkin'! You've definitly done all the right things. It should be a @@@G-Machine! You got any before pics?
Old Apr 4, 2002 | 07:50 PM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
if you take the link in the sig to the pictures, there are a couple of before shots when it looked like a 4x4
Old Apr 4, 2002 | 08:54 PM
racereno's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
Very Nice! Thanks PF.
Old Apr 5, 2002 | 10:24 AM
chevyguy1969's Avatar
Car: 1999 Camaro Z28
Engine: LS1 V8
Transmission: T-56 6spd
Hey PF Flyer, First off... AWESOME CAR!!!! You definitely have the right formula going for your car. Lots of GO and plenty of WHOA! How do you like your Sophn stuff? I have ordered the same stuff you did and I am looking forward to getting them and bolting them on. What kind of power are you making with your engine and all the mods? My next project is a engine build up, wanting around 320-350HP @ the fly wheel. Ive heard alot of good things about the alum. L98 heads and some of the other componets you have. I would love to hear any feedback you can give about your parts and power they make.
Old Apr 17, 2002 | 10:08 AM
cridom's Avatar
:rockon: :lala: :hail: :****:
Jake_92RS
Jan 28, 2020 10:37 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
dyeager535
Aug 28, 2015 08:10 AM
michealleger
Aug 26, 2015 03:29 PM
Fronzizzle
Aug 9, 2015 01:15 PM
