Rear drum to disc conversion?
Old Apr 10, 2002 | 09:26 AM
Dean_O's Avatar
Hey everyone, I have a 92 rs and I want to put my rear end out of my 87 Iroc under it. The 87 rear end has disc brakes. do I need to change the proportioning valve from th 87 iroc to my car or does it matter. Also can I use the same brake lines on the 92 car.
Any tips would be greatly appriciated.
Oh yea does anyone make cross drilled rotors for the rear disc brakes, I already have some for the front but the company that I bought them from does not make the rear.
Old Apr 10, 2002 | 10:02 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
No you don't need to change the P.V. You need the brake lines and emergency brake cables that come with the rear end. You will need to buy a new (or used) parking brake pull-up handle assembly. The pre 89 disc rear end requires the parking brake with a center adjustment rod which came on pre 89 cars (which yours lacks). Yes drilled rotors are available for the rear. I have PowerStop drilled rotors by AutoSpecialty. There is no performance improvment for drilled rotors over solid though. If you buy new e-brake cables (as I did) you may need to cut off the integral spring that is on the end of the cables. E-mail me and I can describe how to cut it off. http://www.autospecialty.com/ Good luck, Lon.
Old Jul 24, 2008 | 11:11 AM
black_highway's Avatar
Car: 91' RS Camaro
Engine: 305c.d. Toilet Bowl Injection
Re: Rear drum to disc conversion?
Why do the springs have to be cut off? I bought new cables and they have been giving me trouble since day one, parking brake doesn't work AT ALL.
jaridjohn
Jul 8, 2024 03:49 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
