Has anybody changed their endlinks ... ?
Old Apr 12, 2002 | 12:10 AM
Belker's Avatar
Have any of you ever changed you old rusty anti-sway bar endlinks by actually removing the nut? I did my rears tonight and the fronts last summer. In all cases, I ended up cutting up the old stuff to get it off. Is this how it is done? Or am I missing something?
Old Apr 12, 2002 | 01:05 AM
87RS402's Avatar
I did. A 1/2' wrench and a 1/2" depp socket/ratchet worked fine for me.
Old Apr 12, 2002 | 01:15 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
well, i sorta did, i got 2 of the four off (right side front, left side rear), and the other two, i tried, but the bolt broke before the nut came off.
Old Apr 12, 2002 | 10:17 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
I don't think I've ever cut them off. I just twist till the nut comes off or the bolt breaks. Usually it's the latter.
Old Apr 12, 2002 | 10:34 AM
vjo90RS8's Avatar
Car: 2002 Z28
I just replaced mine when I put in my 1LE sway bars. Just turn the bolt while you hold the nut in place on the top.
Old Apr 14, 2002 | 10:24 AM
Hellraiser's Avatar
Re: Has anybody changed their endlinks ... ?
When i was wrenching up in the frozen freakin north (new york), we used to cut just about everything off instead of messing with rusted fasteners. If we knew it was going to be replaced anyways, a die grinder with cutoff wheel makes for a quick job.
Hellraiser
Old Apr 14, 2002 | 11:16 AM
sIcK pUpPy's Avatar
These things get pretty jacked up after a while. When converting over to poly, I too snapped off the old bolt trying to remove it. Just the nature of the beast.
Lates,
JD
Old Apr 14, 2002 | 12:03 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I got mine off with wrenches, but they were so badly rusted that the penetrating oil started smoking from the heat.
Old Apr 14, 2002 | 04:26 PM
Dex's Avatar
Dex
That always cool done that MANY times:lala:
customblackbird
Aug 15, 2021 10:16 PM
C409
Jan 21, 2016 08:29 PM
C409
Sep 23, 2015 04:30 PM
C409
Sep 1, 2015 03:42 PM
Thornburg
Aug 25, 2015 01:46 AM
