Intake manifold...how much difference?
Old Apr 22, 2002 | 05:31 PM
CamaroGuy71's Avatar
Car: 2002 TT Corvette
Engine: 5.7L
i wanna replace my intake manifold now that i got the money after spending so much on the internals of the engine. i was wondering... how much of a difference will it make? will i really feel it in the upper rpm range? please let me know asap b4 i go ahead and order one. if its not gonna help much when i punch it on the highway..i dont think i want it.
Old Apr 22, 2002 | 05:34 PM
Snowdog 91 Formula's Avatar
Replacing intake manifold....
Just one question:
With what intake manifold?
Old Apr 22, 2002 | 05:40 PM
Engine: 5.7L
anything that will gove me more top end power... any ideas?
Old Apr 22, 2002 | 05:43 PM
Ideas...
You might want to click your mouse on this thread about intake manifolds: it might give you some ideas!
https://www.thirdgen.org/techbb2/sho...ht=totw+intake
Old Apr 22, 2002 | 06:06 PM
Engine: 5.7L
i want ur ideas on what works best when u punch it from about 60... and how much quicker it will get me to 100.... my car has trouble breathing in the upper rpms it seems..seems to runout of power.
Old Apr 22, 2002 | 06:20 PM
Well, the stock intake manifold leaves a lot to be desired, that's very true. Are you using your stock TBI unit? The Edelbrock and Holley intake manifolds are nice for TBI, or you can look into getting a single plane manifold for more volume. Are you going to be using your EGR system? The Holley/Weiand 300-49 intake is a nice manifold and holds into the higher RPM range. (Around 6000 RPM), but I have older style heads on my engine.
I think the 300-66 is the same manifold with the angled bolt pattern to fit 87-up heads. I'm not sure, you might want to check with Holley. It is an EGR friendly manifold and yes there is a difference.
You might need to get a TBI spacer (about 1/2") so you can fit your EGR valve.
I like what I have, but others might guide you into something better for your needs.
Old Apr 22, 2002 | 07:56 PM
Engine: 5.7L
i have a 1" spacer, and stock tbi unit. i am gonna get camaroracer1992 to do the ultimate tbi mods as soon as i start putting the manifold on. anyone know what ill be lookin at about hood clearance?
Old Apr 22, 2002 | 08:05 PM
1" Spacer with 300-49
Hood clearance will be an issue with that manifold.... If you look at the picture of my car, that hood is raised....
If you are planning on using your stock hood you will not be able to fit it with the 3" open element...
However... you may be able to go with a drop base with a 2" or 2 1/2" element....
Try 2 1/2" first.
Old Apr 22, 2002 | 10:08 PM
HrdRockA4305's Avatar
I'm gonna probaly add the edelbrock TBI one after I get my headers and drop my 2.73s for something better. I've heard its worth a good 10 HP and 30 #/ft of torque, is that about right?
I'll probably pick up a junkyard TBI unit and work that over and just bolt it on with the new intake to help even more.
Old Apr 23, 2002 | 12:35 AM
boogie's Avatar
Hey camaroguy,
I was checking out your mods and see you have 2.02 intake valves. How are you able to use this diameter on a 305?
Lonnie
Old Apr 23, 2002 | 11:25 AM
Engine: 5.7L
i told the machine shop i wanted those valves and they installed them for me. i think i am runing into problems because of those...something like valve shrouding or something. im gonna swap those with smaller valves and see if that cures it. car runs absolutely like **** right now...thats why because i am changing valves i wanna replace the intake manifold also. they fit though... at least the machine shop made them fit.
Old Apr 23, 2002 | 12:51 PM
NTChrist's Avatar
How much $$$ was it to get the bigger valves installed? Did you supply the valves? What kind were they?
You'll run into valve/cylinder wall problems with anything above 0.450" lift, or so I'm told. 2.02 valves will work okay, with anything under. Ask NJSPEEDER. He runs 2.02/1.60's on his 305.
Old Apr 23, 2002 | 06:03 PM
Engine: 5.7L
my cam is about .440 lift ...i dunno exactly... but i think im ok. they are manley stainless valves... i supplied the valves. i also asked for the old valves back to make sure they didnt rip me off or anything...so back to the manifold.....
Jake_92RS
Jan 28, 2020 10:37 PM
masonta
Aug 31, 2015 10:14 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
Jake_92RS
Aug 11, 2015 10:39 AM
