rear-end goes bang..
I wanted to tell my story here to the TBI guys, and i got a question.. so last night i finally got my car on the road it felt like it was running pretty strong... so i pull out of a parking lot and walk on it... going good then the old shift kit kicked into second and bang... got home finally and took the differential cover off nothing but teeth... anyway a did some calling last night and got a used rear with 3:73s and posi for cheap and installed so thats what i am doing tonight...what should i run once i put the gears in??? just curious... and yes i know they are a steep but i am planning a cam swap and intake in the next couple of months.. so any help in numers in which i should run would be good....anyone with similar set ups? thanks corey...
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
my GTECH times were the same with the gears and posi, but i am not sure if it was setup right. car feels much faster and posi makes it fun everytime you want to get on it.
