How to Identify my heads???
Old Apr 24, 2002 | 07:56 PM
Dex's Avatar
Dex
I'm trying to figure out which heads or on my car it is a 350 with 305 heads the original motor was an LO3 according to the VIN but he also told me it was a HO 305 he also said since its a HO 305 if i want to build a motor start with that block i'll stick with a 350
so where are the number to look for back of head?? remove valve cover and look?? thanks:lala:
Old Apr 24, 2002 | 08:47 PM
Tas's Avatar
Tas
on my friends '68 camaro the 327s heads had the number under the valve cover. I don't know if our newer chevys are different.
Old Apr 24, 2002 | 09:25 PM
CamaroGuy71's Avatar
Car: 2002 TT Corvette
Engine: 5.7L
yea...the casting numbers aer under the valve covers. i am actually changine rocker arms again tomorrow so i will write down my casting numbers...they are stock heads just ported, valve job, new valves, etc. but same casting as from the factory.
Old Apr 24, 2002 | 09:43 PM
Dex's Avatar
Dex
I remember seeing a 043 or 430 something while I was in there am i right or wrong
I'm also disappointed I have 2.73 gears but it is posi already knew that and i have custom seats with camaro in them and they have to bad rips in the drivers seat
Old Apr 24, 2002 | 11:36 PM
NTChrist's Avatar
The older 305 heads were 416's.
Try here for casting numbers. Look under chevy head casting numbers, at the bottom of the page.
Old Apr 25, 2002 | 12:07 AM
iroc22's Avatar
It's the same location for the casting #'s as the older V8s
"416" 78-86 305
"187" 88-95 TBI
"081" 87-92 305
92projectcamaro
Jan 18, 2016 08:00 AM
New2Chevy
Sep 28, 2015 12:35 AM
angel2794
Sep 8, 2015 06:22 PM
z28guy134
Sep 1, 2015 11:50 PM
