winaldl problem...
winaldl problem...
Hey, this is frustrating because I made the cable 1 month ago and it worked fine. Now that I come home and try it again it does not work.
I checked the connections a few times. Then I opened up my cable and noticed a solder connection had broken, so I re-soldered it and it still does not work. I checked the diagram and it looks the same as my cable. Any ideas? I did not use a soldering agent but it still soldered anyways(first time soldering).
