Need some TBI specs.......
Old Apr 30, 2002 | 11:39 PM
BowtieFever's Avatar
What is the stock # of PPH for the injectors on an LO3? Also, do you know what the stock fuel pressure is normally set at, from the factory? Thanks!
Old May 1, 2002 | 11:53 AM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
The stock fuel pressure varies from the factory from 9psi to 13psi. My "91" RS is factory set at 12psi as you can see from this Summit fuel pressure gauge I installed.
Old May 1, 2002 | 11:59 AM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
I am pretty sure the stock injector part numbers vary from year to year, but...
this is an old question and has a few answers listed under this link.
https://www.thirdgen.org/techbb2/sho...ighlight=chart
Old May 1, 2002 | 01:43 PM
So, from the specs I have 40 PPH injectors in my LO3? And going to the HOLLEY TBI bumps it up to 57 PPH injectors. Confirm this please.
Old May 2, 2002 | 12:42 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
I believe the stock injectors are 40 pph. The holley 670 does come with 57 pph injectors. It works great. Just give your ECM time to catch up.
Old May 2, 2002 | 02:04 PM
What do you mean by give your ECM "time to catch up?" Thanks!
Old May 2, 2002 | 04:04 PM
snflupigus's Avatar
essentially the ecm is constantly adjusting what it knows about your engine via the 02 sensor to give it a better esitmate of how much fuel it should be letting through the injectors.
if you change injectors etc it will take a while for your ecm to relearn how much it needs for fuel
those are the simple terms if you want to know more, find info on blm and integrator numbers.. do a search.
Old May 2, 2002 | 04:09 PM
DM91RS's Avatar
Car: 91 RS
I still have the stock injectors on my eng so unless you're adding alot more mod's or CI you don't really need more. FYI I have also tried the LO5 cop car injectors on this set-up and it was way too rich.
Old May 2, 2002 | 04:21 PM
JR305's Avatar
I have 350 injectors for my setup, will they be too much and what fuel pressure should I set them at
Ported World S/R torquer 305s
Edelbrock TBI manifold
ZZ4 cam (208/221 .474/.510 112)
slp headers
highflow cat
3" catback
currently:
305 injectors @ 11.5psi
slp headers
highflow cat
3" catback
Old May 2, 2002 | 04:36 PM
DM91RS's Avatar
Car: 91 RS
slp headers
highflow cat
3" catback
currently:
slp headers
highflow cat
3" catback
You'll have to try them and see IMO. I could not turn the psi down low enough to not be running too rich and tried the 305's and they worked fine. I only installed the 55lb injectors because I was advised that I would need them. And I had them on hand. In your case you will be trying more cam and you might need them.
Old May 2, 2002 | 04:44 PM
JR305's Avatar
DM91RS... What psi are you running your injectors at? Also how much hp do you think you are making.
Old May 2, 2002 | 09:09 PM
DM91RS's Avatar
Car: 91 RS
The psi varies from 10.25 to around 11.5. Why it varies this much I don't know but I do have an electric in dash guage to keep a check on it.
As far as how much power the thing is producing....I'm not one going to make a quess on that....which is all it would be. I believe dyno printouts or 1/4 mile speeds would be the only way to determine that with any accuracy.
I don't know if a G-teck is accurate or not. I've got one but havn't used it since the cam swap. It showed 93-94 mph if I remember correctly and from what I've read those numbers are usually high to actual 1/4 mile times.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
