350 v/s 305 chip (PROM)
Old May 3, 2002 | 10:50 PM
svaras's Avatar
Is it possible to run a 350 with a 305 chip ?
I bought an ECM from a 305 TBI for my 350. ( My engine didn't came with the ECM)
Any info about what troubles should I run into will help
Old May 4, 2002 | 01:16 AM
JPrevost's Avatar
Car: 91 Red Sled
It won't run too hot for lots of reasons. Timing, heads, valve size, injectors. The only thing that's in common is that they have 8 cylinders and are small blocks. The different bore to stroke ratio is enough to make for some serious timing troubles. If I have the time tomorrow I'll post the differences between the stock TBI 305 and 350 eproms.
If it's a near stock 350 L05 then use/get the ANLU eprom. Either call some dealers or I could burn you one for the price of the eprom and shipping. I don't do custom eproms over the e-mail unless the car is EXACTLY like mine (only know of 2 people and one is already burning his own and other went to carb).
The stock ANLU eprom is very good start for a 350 tbi. It's usually a good rule to start with something that had the same bore/stroke ratio at least. So if you stroked to a 383 then you might be looking at using something like a 305 eprom but it's SO much more complicated than that. Long story short, mild 350 TBI, use an ANLU eprom with modified tcc lock/unlock tables. Removing stuff like EGR and the speed limiter isn't a problem either.
Try out the 305 first, if you don't like, think about the ANLU.
Old Aug 8, 2019 | 02:48 PM
Sonoma92's Avatar
Re: 350 v/s 305 chip (PROM)
Would you still make a ship a EProm? I am currently looking for one. Pretty basic stock 350 tbi set up.
Old Aug 8, 2019 | 03:54 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Sent you a pm
Glowsock
Jul 24, 2025 03:15 PM
Jake_92RS
Jan 28, 2020 10:37 PM
NWAsonoma
Aug 18, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
djmarch
Aug 11, 2015 10:22 AM
