advancing timing?
Old May 5, 2002 | 06:18 AM
91RS5spd's Avatar
Car: 1990 Camaro RS (IROC-Z Clone)
Engine: LO3
Axle/Gears: 3.08
advancing timing?
How do ya'll advance the timeing on you lo3's, You turn the distributor cap right? but witch way, counter clockwise or clockwise? When I do this will I need to up my fule pressure? If so how do I do that Thanks
Old May 6, 2002 | 11:43 AM
91RS5spd's Avatar
Engine: LO3
Axle/Gears: 3.08
ttt
Old May 6, 2002 | 01:37 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
read the tech article.
fuel pressure is a very "car-specific" thing. only you will know by doing it if it needs it or not.
Old May 13, 2002 | 10:49 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
counter clockwise for advance, don't forget to unplug your EST
Old May 14, 2002 | 12:03 AM
TBI305Camaro's Avatar
EST is right above the heater/AC fan thing on the pass side firewall above the wiring harness near the top...disconnect it, turn off the car, turn the car on and adjust away...comp will change it alot when you plug it back up. i put my base timing at 12 then when i hooked up the EST it took it up even further...if i put it at 0 the comp puts it to 12...so im guessing the computer knows whats up i dont know
Amillionoh7
May 24, 2020 08:01 AM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
Thirim
Aug 9, 2015 06:19 PM
djmarch
Aug 9, 2015 05:27 PM
