ok guys a little help on this one
Old May 8, 2002 | 07:41 PM
rsc350's Avatar
Car: 92 Camaro RS
Axle/Gears: 3.73 Truetrac
OK I have a 350 TBI, which is better for air flow... open element with the rubber removed from the rear of the hood, or a dual snorkel?
Old May 8, 2002 | 08:40 PM
CamaroGuy71's Avatar
Car: 2002 TT Corvette
Engine: 5.7L
im goin with the open emement with the rubber removed..sounds sweet when u step on it and hear the hiss of the air cleaner..although i did see water spots all over the chrome after the rain!
Old May 8, 2002 | 08:59 PM
Tallboy's Avatar
i bet two cars being equal in every way
an open element would win in quarter
if both were allowed to heat up till fan comes on i think it might go the other way
if both cars are cruising and in last gear and both punched i'll go with open element
i walked away from a formula doing a stomp on gas at cruising speeds...it didnt have the go fast parts(2.73's,twig cam, but it was a tpi,88)and i think i have the open element to thank for that
but this is an age old debate
i like my open element
but am actually thinking of doing the formula hood
fresh air mod,anybody done this????
modhttp://www.angelfire.com/nb/thirdgen/air.htm
go to track and let us know
i dont think ill be surprised
Old May 8, 2002 | 09:34 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
depends on the motor...
if you NEED the air flow, an open element will be the way to go. you have a 350, and i am assuming that it is a little more geared towards performance, so you will probably be in this category.
now, if you have a pretty stockish engine, you wont need the added air flow, so either way you will be ok.
definitely take off the hood weatherstripping though.
-brian
Old May 8, 2002 | 09:48 PM
NJ SPEEDER's Avatar
teh thing to remeber is that all differences in air temp/density can be negated by a proportionally greater volume.
the example with our cars is that teh small tubing size and turbulance from all the little ridges in teh tubing allows enough less total air to be drawn by teh engine that an open element, even though the air is clearly warmer, will allow for more air to be drawn.
later
tim
Old May 8, 2002 | 10:11 PM
rsc350's Avatar
Car: 92 Camaro RS
Thanks guys, keep the opinions comeing right now I think the dual snorkel would look better but the open element is the way to go... I think, maybe someday ill get the ram air hood I want too and that open element will get some cold air....someday...
Old May 9, 2002 | 08:18 AM
Buck268's Avatar
Unless you got plenty of extra cash, go open element. If you get a dual snorkle set up, plan on $100 or more! I cant justify that fer like 5-10 hp...
EDIT: that estimate on hp gain is high - IMO
Cleotiz
Jan 6, 2018 08:56 PM
aaron7
Aug 17, 2016 06:02 PM
PestilenceIV
Aug 20, 2015 03:32 PM
Street Lethal
Aug 14, 2015 08:25 PM
Zachattack0925
Aug 12, 2015 09:52 PM
