Timing...
Old May 16, 2002 | 09:53 PM
JR305's Avatar
Timing...
Ok I have the car running, idle sounds bumpy, just wondering what I should set my base timing at.
I have an edlebrock TBI intake, world s/r torquer 305s, and a zz4 cam installed.
Old Nov 5, 2002 | 09:13 PM
lo-n-slo's Avatar
did you ever get an answer ive got a tbi 350 with a zz4 cam and would like to know what base timing seems to work best!!!!
Old Nov 6, 2002 | 12:29 AM
JPrevost's Avatar
Car: 91 Red Sled
Try setting it at 6, then go up 2 degrees until performance falls flat on it's face, then back off 2 degrees. It'll probably take you 4 or 5 runs in the 1/4 mile but look at mph not ET.
Any aftermarket heads and cam should need a custom eprom. If I were you guys I'd look into getting the $250 to burn your own eproms or go with a carb and mechanical dissy.
Old Nov 7, 2002 | 06:11 PM
JR305's Avatar
Mine ran best at 8* under the stock prom. But JPrevost is right, you will need a custom prom.
Old Nov 8, 2002 | 12:31 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
I have my setup (lt1 cam, vortec heads) at 10* advance, but I'm gonna back it off a little more to about 8 and see what happens. My *** really needs a prom
Old Nov 9, 2002 | 08:04 PM
lo-n-slo's Avatar
i have a custom chip made does that matter? I cant put a carb on it (easy anyway) because i have a 1994 truck with an electronic 4l60e transmission.
Old Nov 10, 2002 | 11:12 AM
JR305's Avatar
You should ask who made the chip what base timing you should be running. Whoever burnt the chip for you probably added a lot of timing to it.
z28cmr83
May 26, 2015 08:48 PM
gta892000
Dec 19, 2014 06:55 PM
Sonix
Carburetors
18
Apr 21, 2005 12:13 AM
Steve89GTA
Apr 16, 2001 08:08 AM
TomP
Apr 1, 2001 10:54 AM
