swap trottlebody
Old May 24, 2002 | 01:34 PM
Firebird sweden's Avatar
Car: Firebid Cab-92/1989 TTA
Engine: 383 HSR TPI
Transmission: TH700r4
Axle/Gears: 4.10
swap trottlebody
I am thinking of swap my 305 to a 350 and wounder if I can use my stock tb whith a jet stage 2 chip or do I have to go whith a lager tb.
Firebird sweden
Old May 24, 2002 | 02:14 PM
NJ SPEEDER's Avatar
if the 350 is mild you can use teh stock tb and injectors. if you 350 is going to be a step or two up from stock you will definately want to go with a little bit bigger injectors.
the only time you woudl really "need" a larger tb is if you are going for a lot more performance, any time you are trying to get above 300hp i think it is a good idea. below that level the stock tbi with ultimate tbi mods will get the job done.
thanks
tim
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
