thinking of going with 454/4L80E tbi...
Old May 24, 2002 | 08:46 PM
super chevy's Avatar
Got a line on a tbi 454/4l80E out of a '94 3/4 ton truck for $1000.
With a few mods, I should finally get the torque I've been looking for. SC
Old May 25, 2002 | 11:30 AM
NJ SPEEDER's Avatar
that would be a sweet deal. a local guy has a 454SS truck that ran a 15.4 at 87mph. that is pretty strong when you consider that the motor is dead stock in a 5000lbs truck. only mods he has are an open element(14x5 ), cat back, and 4.10 gears(3.73's were stock).
if you can do a little work to it while it is out you would really be flyin. edelbrock makes a big block performer tbi, any number of companies make good heads, a mild cam, and a full exhaust. all the regular tunign tricks for tbi apply exactly the same.
later
tim
Old May 27, 2002 | 05:34 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
you are gona get about 8 mpg ya know. is that the vortec 8100 or the earlier engine?
Old May 27, 2002 | 11:39 PM
iroc22's Avatar
It's the pre Vortec Mark V 454 he's got. Oh and I would stay away from the 4L80E for a couple reasons. It's only a 3 speed, reliability problems and horsepower capacity.
Old May 29, 2002 | 03:42 AM
nsimmons's Avatar
the 4l80e is a 4 spd. hence the 4 in its name, its a turbo 400 with an overdrive, its bullet proof and cost 3 grand. Keep it! its an awesome score.
Old May 29, 2002 | 06:48 PM
NJ SPEEDER's Avatar
hmmm, 4L80E= bullet proof over drive i am thinkin it is time for some serious gears use all 4 in the quarter adn have it be killer consistant since you can just use an electronic over drive controller from a 4L60E. hehe
what is the over drive in teh 4l80?
later
tim
Old May 29, 2002 | 09:49 PM
steve8586iroc's Avatar
The 4L80E trans is set up like the 4L60E but needs a stand alone controller to be used in a none comp (pcm) vehicle. It is as strong as the TH400 and also heavier. It would work well behined the big block but might not be a good trade off in a camaro behined a small block. As far as the OD I think it is the same as the 4L60 .70/1 .
Steve
Old May 29, 2002 | 09:57 PM
JPrevost's Avatar
Car: 91 Red Sled
4L80e is a TH400 with overdrive, same ratio's (2.48, 1.48, 1.00) and with a .75 overdrive. I believe it's just slightly larger in size than the 200r4 and it requires a shorter driveshaft because it's the longest tranny GM has, not sure if you can swap tail-shafts or not.
Too bad they're so expensive.
Old May 29, 2002 | 10:33 PM
iroc22's Avatar
Damn I'm wrong, I always get the 3L80 and 4L80 goofed up but why would I? (3-4) Oh well, I believe the tailshafts can be swapped and they did come with quite a few different tailhousings. The 4L80E is 3 inches longer than the 400, so you'll need to contact someone like Denny's Driveshafts. The Th200-4r is a lot smaller and tons lighter than the 4L80E. The Th200-4r is smaller and lighter than the TH700-r4.
chazman
Aug 28, 2018 03:25 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
midge54
Jan 29, 2017 07:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
