Results from dyno....not for the squeemish
Old May 28, 2002 | 05:44 AM
91RS5spd's Avatar
Car: 1990 Camaro RS (IROC-Z Clone)
Engine: LO3
Axle/Gears: 3.08
An all incredible 163hp and 275lb/ft Well it's not what I hoped for, I was hopeing for at least 180hp. But I guess if you look at it from a possitive view im now putting at or around 200hp at the fly and over 300lb/ft that the fly as well witch is about 30hp and 50+lb/ft more then stock. I think I have a bad knock senser and a small leak around my headers so maybe after I check tho's two things ill get a couple more hp out of it. I also have in the mail some march underdrive pulley's, a jet chip, flowtech cut out, and a fan switch. So ill give ya'll an up-date from my next dyno next month on how much that stuff improved me.
Old May 28, 2002 | 08:29 AM
91Firecrow305TBI's Avatar
That should help. Remember your big restrictions Intake Manifold/Cam/Heads.
Old May 28, 2002 | 10:30 AM
vjo90RS8's Avatar
Car: 2002 Z28
With headers and a complete exhaust, i think 30HP and 50ft lbs is a pretty good gain. Add an LT1 cam , and an edelbrock TBI intake and you should be well over 200rwhp and 300rwt
Old May 28, 2002 | 12:12 PM
iroc22's Avatar
That's really impressive since you're only upgrades are exhaust.
Old May 28, 2002 | 02:35 PM
91RS5spd's Avatar
Engine: LO3
Axle/Gears: 3.08
I was pretty down on my self but again I really am not expecting much untill I do get my heads, intake, and cam. But if ya'll think thats pretty good with what I got then I am encouraged Would adding roller rockers help on stock heads? I hear adding 1.6 roller rockers would be like putting a bigger cam in, is this true, or should I stay with 1.5.
Old May 28, 2002 | 04:19 PM
vjo90RS8's Avatar
Car: 2002 Z28
lets look at your numbers alittle closer. Ok, you have a 5 speed, so assume 15% loss from the drivetrain
Stock
170 HP --> ~145 rwhp
255 ft lbs --> 217 rwT
Your car
163 rwhp --> 192 HP
275 rwT --> 324 ft lb
So assuming 15% loss, you gain about 22 HP and 69 ft lb at the flywheel or 18 HP and 58 ft lbs at the rear wheel. Still a pretty good gain from just an exhaust and open element.
Old May 28, 2002 | 05:31 PM
iroc22's Avatar
Getting some 1.6 rockers will increase cam lift and horsepower.
Old May 28, 2002 | 05:41 PM
vjo90RS8's Avatar
Car: 2002 Z28
1.6 rocker arms with that peanut cam will not do you any good. Get an LT1 cam (50 shipped), new springs (K Motion $42), and a new timing chain + misc parts (~100), spend that $200 on something that will definately make you some power. Dont waste it on a stock engine.
LT1 cam w/ 1.5 rockers: .447/.459
stock cam w/ 1.6 rockers: .373/.405
Old May 28, 2002 | 05:58 PM
steve8586iroc's Avatar
vjo, look at his user name, RS91 five speed.
Old May 28, 2002 | 06:12 PM
NJ SPEEDER's Avatar
30ponies from air filter and exhaust. damn good i think. using the old basic rule of thumb you can figure 30hp is about 3 full mph of trap speed at the track.
do you have ultimate tbi and diy afpr yet?
can't wait to hear the next set of numbers form ya. keep up the good work.
later
tim
Old May 28, 2002 | 07:23 PM
vjo90RS8's Avatar
Car: 2002 Z28
ok, i changed my calculations
Old May 29, 2002 | 05:31 AM
91RS5spd's Avatar
Engine: LO3
Axle/Gears: 3.08
I don't have the ultimate TBI mod's yet, Id like too tho! Ill be doing more seirious mod's after I get back from Afgan in Dec. It'll be intresting to see the improvements.
Falcon50
Aug 22, 2020 03:26 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
Thornburg
Oct 6, 2015 12:04 PM
gord327
Oct 3, 2015 01:25 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
