Need help with winaldl cable
Old May 28, 2002 | 05:54 PM
steve8586iroc's Avatar
Anyone know where to pick up the 12v source on a DB25 connector? The diagram at Joby's web site shows the DB9 connector but not the DB25 connector.
Steve
Old May 28, 2002 | 09:20 PM
MightyMouse's Avatar
Car: 90 RS
Engine: 383
Axle/Gears: 3:23
Use a multimeter to find it, just make sure the port is open when you go probing for it. On a db9 the polarity is reversed until the port is opend(start winaldl).
Old May 28, 2002 | 09:29 PM
Thanks MM, so your saying that the DB25 has a 12v source some where? Can I mess up my laptop if I touch the wrong pins at the same time? I should have bought the DB9 connector instead but I'm just trying to make what I have work.
Steve
Old May 28, 2002 | 09:44 PM
Car: 90 RS
Engine: 383
Axle/Gears: 3:23
That is how I did mine and I did not mess anything up but mine is a db9 and I dont know if a db25 has power but it should. My laptop only puts out about 9-10v but it works fine. Good luck.
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
